Reply 480 of 2212, by rcblanke
- Oldbie
wrote:wrote:DBGL has started to lock up frequently, I suppose I could do a clean reinstall but I've had this problem before. It won't let me add profiles without locking up and it won't let me execute games without locking up.
Check the paths to DOSBox on the DOSBox versions tab.
Hi guys,
Could you please explain what was the problem, exactly? Because, a misconfigured DOSBox directory location should not result in lock-ups but simply display a message explaining the problem. I'm unable to reproduce the issue. But If YOU can, would you be as kind to send back the stacktrace?
Thx,
Ronald
