Hi everybody,
some good news: I have finished the work on the demos package. I will upload it the next days. It will contain 119 demos from http://pain.scene.org/ (old demos package: only two demos). And I have started working on D-Fend Reloaded 0.8. In the next version I will try to improve the auto setup handling (more checksums per template to improve game detection, better results dialog when scanning the games folder, option to choose the template to use when importing plain zip files, etc.). And of course the next version will bring full DOSBox 0.73 support.
To answer some of the last posts:
Running DOS games from DFR without DOSBox
When adding games in "Windows game" mode via the wizard or via the full profile editor DFR will warn the user if he trys to add a DOS program this way. If the user ignores this warning and continues anyway there is nothing I can do. (BTW: DFR also warns the user if he selects a Windows exe when editing a DOSBox profile. - This should reduce the "What does 'This program can not be run in DOS mode.' mean?" forum questions.)
Empty line in games list
If you resize the DFR window you will see the empty area at the bottom of the games list getting bigger and smaller. It appears because the games list always starts at the begining of a line and the list only displays complete lines. The empty data area is also right: If you click the empty area in the games list you unselect any profile and if no profile is selected there is nothing to show there.
320x240 resolution
I will add this to the default values list offered by default.
More options in multiple profiles editor
-> Added to my 0.8 todo.
One request from me
As I have already written some time ago:
D-Fend Reloaded 0.8 will also bring a better image scaling algorithm for screenshots (games list in screenshot mode, image previewer are and image viewer dialog). You can already test some different scaling algorithms by adding the line "ImageFilter=..." to the [ProgramSets] section in DFend.ini. Valid values are 0 to 8. "0" is off (the default in DFR 0.7), "1" is a very slow and simple scaling algorithm (using the pixel property to access the pixels) and "2" to "8" are some fast, more advanced fiters directly accessing the image scanlines. At the moment I'm not sure if I will offer an option to change the image scaler or just setup the best for use in 0.8. So please tell me which one is working well for you.
Could you please test the different scaling modes and tell me which is the best for you?
