Linux portable version?
First post, by dark2025
Hi, I am very new to Linux and I am using Ubuntu 9.04. I am wondering if I can put DOSBox on my USB stick to make it portable. I tried extracting the install file to it and it didn't work, so now I'm out of ideas. Anybody have any suggestions?
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
you want to extract the windows installer under linux to make it possible to use on other pc's ?
7zip can extract it.
Water flows down the stream
Reply 2 of 4, by dark2025
Actually I would like to be able to use it straight from the USB drive in Linux, without having to install it first, just plug in the drive and open up the executable. I've done this for the Windows version, but don't know how to do it for a Linux version.
I know I can just easily install it onto the hard drive, but for reasons I won't go into that is not very preferable for me.
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
well you would have to compile dosbox staticly
Reply 4 of 4, by dark2025
Thanks... It took me a while to figure out how to compile it, but now it's working perfectly as I wanted it. Thanks.
