Championship Manager 2 - PC
First post, by Az
I have vista 64 bit and I have tried loading up the game through dosbox, I have it on CD and downloaded a version from the net, when I try the one through the CD I get to the CM2.exe part to load the game up and dosbox just closes, the downloaded version comes up saying it needs the CD!
Anyone got any ideas as I am truely a novice to this kind of thing and used the Basic Setup and Installation of DosBox page on the website.
edit: I have tried the 60 second guide and tried that, but the same thing happens, once installed it says type go to load up the game, I did that and dosbox closes.
Reply 1 of 30, by lightmaster
here's a cool patch by peter ferrie
download.php?id=6045
Reply 2 of 30, by Az
Thanks, as I said I am quite a novice with this type of thing so what do I do with that?
Reply 3 of 30, by lightmaster
unzip it into the game's folder and run it under dosbox.
Reply 4 of 30, by Az
I have put it in the folder and still says needs CD.
Reply 5 of 30, by lightmaster
then first you need to read the guides on how to mount a cd or make a cd image i suppose.
Reply 6 of 30, by peterferrie
No, that download is a patch to DOSBox sources.
The non-source CM2 patch is available from my site:
http://pferrie.tripod.com/misc/dosbox.htm
Download the cm2fix.zip, unzip that file into the CM2 directory, then run cm2fix.com instead of cm2.bat, each time you want to run the game.
Reply 7 of 30, by lightmaster
oh my bad hehe, nice patch btw!
Reply 8 of 30, by Az
peterferrie wrote:
No, that download is a patch to DOSBox sources. The non-source CM2 patch is available from my site: http://pferrie.tripod.com/mi […]
Thanks for that and I have finally got it running! Problem now is everytime I want to play it I need to go through it and install it, on the 60 seconds guide page - 60 seconds guide to getting your game to run in DOSBox
it says:
If you have more than 60 seconds to spare, use Notepad to edit "%ProgramFiles%\DOSBox-0.72\dosbox.conf" and add the mount commands to the section named autoexec (at the bottom of the file):
I have tried finding the file but cannot find it anywhere, I have vista and have even tried doing a search but cannot find it!
Reply 9 of 30, by lightmaster
you'll have to search the conf file because its on a different location under vista i think/guess..
Reply 10 of 30, by Qbix
Rank DOSBox Author
DOSBox Author
use the shortcut in the startmenu of dosbox.
Water flows down the stream
Reply 11 of 30, by Az
Haha bullseye!
The game is installed in
C:\Users\Aaron\Documents\DOSBox stuff\MyGame\CM2
Dosbox is installed in
C:\Program Files\DOSBox-0.73
I have edited the dosbox.conf notepad file with:
[autoexec]
Z:\>mount C "C:\Users\aaron\Documents\DOSBox stuff\MyGame"
Z:\>mount i "i:" -t cdrom
C:
(I: drive is my DVD/CD drive)
and saved it as "MyGame-dosbox.conf" and put it in the CM2 file, I have changed the dosbox shortcut on my desktop to "C:\Program Files\DOSBox-0.73\dosbox.exe" -conf "C:\Users\Aaron\Documents\DOSBox stuff\MyGame\CM2\MyGame-dosbox.conf" but it isn't working, I am probably missing something obvious.
I am sorry for being a pain in the ass with me being such a dummy on this stuff, but i really do appreciate your help!
Reply 12 of 30, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
What isn't working? What does the console window of Dosbox say? (it should tell you which conf is used).
Anyway it should be
mount d "i:\" -t cdrom
C:
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 13 of 30, by Az
Dominus wrote:
What isn't working? What does the console window of Dosbox say? (it should tell you which conf is used). Anyway it should be mo […]
Anyway it should be
mount d "i:" -t cdrom
C:
When I open the shortcut dosbox just opens with the normal startup, Z:
Reply 14 of 30, by MiniMax
Rank Moderator
Moderator
You should get 2 windows: The normal DOSBox window with Z: and status window. In the status window it should show which config file is being loaded (or not).
_________________
Reply 15 of 30, by Az
Or not indeed, I have loaded up both the original dosbox and the config one and both have the same status window 😢
Reply 16 of 30, by Qbix
Rank DOSBox Author
DOSBox Author
check the -conf parameter path again.
Reply 17 of 30, by MiniMax
Rank Moderator
Moderator
1) Open a CMD-window and try this:
?:\> C:
C:\> cd "\Users\Aaron\Documents\DOSBox stuff\MyGame\CM2"
C:\> dir MyGame-dosbox.conf
Do you see your MyGame-dosbox.conf file?
2) Next:
C:\> "C:\Program Files\DOSBox-0.73\dosbox.exe" -conf "MyGame-dosbox.conf"
Do the status window show that MyGame-dosbox.conf is being loaded?
3) Now try:
C:\> cd "\Program Files\DOSBox-0.73"
C:\> dosbox.exe -conf "C:\Users\Aaron\Documents\DOSBox stuff\MyGame\CM2\MyGame-dosbox.conf"
_________________
Reply 18 of 30, by Az
MiniMax wrote:
1) Open a CMD-window and try this: […]
?:\> C:
2) Next:
3) Now try:
File not found.
The MyGame-dosbox.conf file is a notepad, so its a .txt file 😕
Reply 19 of 30, by MiniMax
Rank Moderator
Moderator
So? Then change your shortcut so it uses "MyGame-dosbox.conf.txt". How difficult can that be?
_________________
