Severe Tearing in RIPPER
First post, by highnrg
Hello,
I've read the threads about the graphics issues with Ripper. I already installed the patches, which got the game to run.
The movies work fine, but the actual animations and gameplay has SEVERE tearing.
What were some solutions to this problem? I couldn't find any conclusions ... just a bunch of ideas ... in the threads before.
Narrowing it down, what could be done to fix this?
Is it something with my .conf setting?
Reply 1 of 19, by eL_PuSHeR
What have you tried so far? I assume you are using dynamic core.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 19, by highnrg
Forgive my ineptitude, but what is 'dynamic core?'
i have a mac g5, and haven't really messed with any special conf. settings, patches, or executable add ons.
just copied the iso's to my hard drive, downloaded the patches (which actually got the game to run) and tried to mess with the frameskip on .conf file. thats about it.
what do u suggest?
Reply 3 of 19, by wd
Rank DOSBox Author
DOSBox Author
At least we know your operating system now!
Reply 4 of 19, by robertmo
highnrg wrote:
what do u suggest?
reading documentation
Reply 5 of 19, by ripa
I don't know if Ripper has tearing in real dos, but if not, change output= in dosbox.conf to something else. I think opengl doesn't tear on a Macintosh in windowed mode. Also, turn on doublebuffering (fulldouble=true).
Reply 6 of 19, by highnrg
robertmo, i've read quite a bit of documentation and basically figured out how to use dosbox in the past two weeks.
i don't really need your sarcastic remarks. thanks.
... as for the doublebuffer, i'll give that a try.
what is dynamic core?
Reply 7 of 19, by highnrg
double buffer didnt work 🙁
surely someone else must have had a similar problem?
Reply 8 of 19, by eL_PuSHeR
Dynamic core is mentioned in the readme file. You should read it, honest.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 19, by ripa
Does it tear using output=opengl and fullscreen=false? I don't think I ever got dosbox not to tear in fullscreen on a Macbook.
Reply 10 of 19, by highnrg
i changed fullscreen=false in the .conf file, but it did not change anything.
i could not find any option to change the output to output=opengl
i also can not find the readme file to look up dynamic core 🙁
Reply 11 of 19, by highnrg
Okay, so i changed fullscreen=false, output=opengl, core=dynamic
...but i have a feeling that none of the changes in the .conf file are actually doing anything.
there is no noticeable change in dosbox.
why is this?
Reply 12 of 19, by robertmo
read dosbox guides how to speed up dosbox
Reply 13 of 19, by MiniMax
Rank Moderator
Moderator
Before you do anything else, experiment with the cycles setting in that config file of yours. Set it to
cycles=fixed 1234
and start DOSBox. Look at the window title. What does it say about cycles?
_________________
Reply 14 of 19, by highnrg
The cycles say 3000, then it goes to MAX once the game starts.
Every change I've made with dosbox.conf, nothing in the actual program changes. I'm thinking I may be making a simple error?
Is the dosbox.conf file supposed to be located in a certain directory otherwise it won't work?
Literally, every change I make it dosbox.conf does not have an effect on the actual dosbox
Reply 15 of 19, by madpanic
Just a thought, are you restarting DOSBox after you change the conf file?
Reply 16 of 19, by highnrg
Yeah, of course.
Where is your dosbox preferences.conf file located?
Mine is in my preferences folder? (but i have a mac)
should it be somewhere else?
Reply 17 of 19, by robertmo
try this game on wixp
Reply 18 of 19, by MiniMax
Rank Moderator
Moderator
Wrong name perhaps? I think it should be named "DOSBox 0.73 Preferences" or something like that. I am too lazy so check my 60 secs guide.
_________________
Reply 19 of 19, by highnrg
so as an update...
i figured out how to use the dosbox.conf file, and get it actually to effect my dosbox. i basically open up terminal, drag dosbox to the terminal, then type -conf then drag the .conf file over to terminal, and it opens the program with the corresponding conf file.
HOWEVER....
none of the suggestions have worked.
they pretty much made ripper run slower. double buffer = slower, core=dynamic = slower.
Im about to give up, and wait till I get a pc...
but thank u for ur help.
any other suggestions are def. welcome. ... i just cant believe it's being so slow?!
