First post, by TeaRex
I can't seem to find a cpu speed setting where the lip synch in the Ultima VII intro is correct without the game proper being much too fast to use.
I use 0.73 on Windows XP home SP3. Machine is a Aspire One netbook, Intel Atom processor @ 1.6 GHz, 1 GB of RAM. No frontend is used, I prefer to edit the configuration directly. Complete .conf is attached.
At cycles=max the lip synch works, but the sound stutters a bit (even with large prebuffer values) and of course the game runs too fast, NPCs zip around like they've had several bars of that Nazi Pilot Chocolate.
At a playable cycles=9000 or so, the lip synch is completely messed up, the speech finishes long before the guardian animation stops moving its mouth.
Any ideas?
tearex
Reply 1 of 7, by robertmo
core dynamic and more cycles
Reply 2 of 7, by MiniMax
Rank Moderator
Moderator
Maybe
cycles=max 80%
(which will leave CPU cycles to do the sound emulation)
_________________
Reply 3 of 7, by TeaRex
robertmo, thanks but I'm already using the dynamic core, and adding more cycles makes the game too fast, as I wrote.
MiniMax, I tried your suggestion, also with lower numbers. The result was the same as for plain cycles=max: stuttering in the intro and a game that runs too fast to be playable.
I also tried using the normal core -- without success.
Thank you two anyway for your help.
tearex
Reply 4 of 7, by HunterZ
You mentioned trying a larger prebuffer, but have you tried increasing the blocksize= setting?
You might also try messing with the video settings in case it's an issue for the video hardware being too weak. Try fullresolution=original (I think) and scaler=none, and try different output= settings with it.
Reply 5 of 7, by ADDiCT
Let me throw a theory into the discussion. I don't know the game, but what if the "synching" is just a figment of imagination? I can remember only a handful of DOS games that had more or less good synching (LucasArts adventures come to mind). I mean, many DOS machines had a hard time playing videos at all, not to speak of perfectly synchronizing video to audio on a multitude of possible hw/memory configs, without some sort of common API.
EDIT: ah, i've missed an important part of the original post. My theory could explain a small a/v discrepancy, not what the op has described.
Reply 6 of 7, by TeaRex
I've found the culprit. It was fulldouble=true.
With fulldouble=false, things work very well.
Howver, in the course of experimenting, I found a couple of strangenesses:
fulldouble doesn't seem to be compatible with output=surface. The screen was very messed up.
Only output=ddraw will scale up machine=vgaonly mode 13h output to 800x600 with aspect=true and scaler=none. The other hardware-accelerated output= options will leave a black border, seemingly using 640x480 only. This behaviour disappears with machine=svga_s3.
The ddraw scaled output looks much better (less mushy) with machine=vgaonly than with machine=svga_s3.
In short, there seem to be a bunch of strange interactions between the various options.
tearex
Reply 7 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
vgaonly uses the 16bpp color mode which results in the effects you observed. The scaler code for the non-working output modes is not ready for that.
1+1=10
