Command and Conquer on a Macbook with DOSBox
First post, by kardon
I am trying to use DOSBox to install Command and Conquer. So far I have mounted a folder to be my "C:" drive, but I am very computer illiterate and do not know how to proceed further. I have the ISOs for the GDI and NOD disks on my computer, and burned onto CDs.
Reply 1 of 20, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too). Instructions for Mac is on "page" 2.
As you have ISO-images of the disks, you can choose to use the IMGMOUNT command instead of the normal MOUNT command. See the README file for details.
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 20, by kardon
I got an "illegal command: win" when I tried to run the install.exe and setup.exe.
I mounted my "C:" drive by typing MOUNT C ~/DOSGAMES after creating the dosgames folder under users/[my user name]/
I mounted my cd by typing "mount D /Volumes/gdi95 -t cdrom
I typed d: to switch to the cd, then dir to see whether there was an install or setup file. There was both, but when I typed "install", "install.exe", "setup", or "setup.exe", I received an "illegal command: win" message.
The version of CnC I have is the free version available for download that was released for CnC's anniversary.
Reply 3 of 20, by DosFreak
Those are all Windows executables. It's likely that that version does not have the DOS install. If it is C&C for Windows 95 then it does not.
A long time ago I uses the expansion DOS files to run C&C 95 and it worked fine.
Make your games work offline
Reply 4 of 20, by MiniMax
Rank Moderator
Moderator
Strange.
SETUP is the program you should use.
Same here. I am attaching the configuration file I used. Adjust the mount commands used, and it should work for you too.
_________________
Reply 5 of 20, by kardon
The configuration file you used says "Red Alert". Would that work for Command and Conquer Gold as well?
How would I use the configuration file? I am unfamiliar with the .conf extension.
Reply 6 of 20, by Miki Maus
AFAIK, Red Alert CDs come with both Win and DOS versions, but C&C Gold CDs with Win only.
Reply 7 of 20, by kardon
I have installed Red Alert instead of CnC Gold, and when trying to play it I get the message to insert the CD in the CD drive, which I did. The game cannot seem to detect it.
I have mounted the C drive and the CD drive.
I have successfully installed Red Alert.
I typed "RA" on the C:\westwood\redalert> prompt, which loads the game but tells me to insert the CD in the CDROM drive. DOSBox can see the CD, but not the game.
Reply 8 of 20, by MiniMax
Rank Moderator
Moderator
Try adding an -ioctl option to your CD-mount command. Or better, use IMGMOUNT to mount the CD-image.
_________________
Reply 9 of 20, by kardon
I mounted the image with:
imgmount d ~/doscd/cd1_allied_disc.iso -t iso
AND IT WORKS NOW! THANKS!
Reply 11 of 20, by kardon
New problem. Unrevealed terrain remains unrevealed when explored. instead, what is left behind is a trail of white because the cursor is white.
Resolution also seems low, but I assume that is normal for games of that era.
Game also crashed when I tried to start a new game after aborting the first mission.
EDIT: screenshot of explored terrain being streaks instead of the actual terrain.
Reply 12 of 20, by MiniMax
Rank Moderator
Moderator
DosFreak wrote:
I thought the C&C CD's had CD Audio tracks?
The download is an RAR-archive with an ISO-image inside.
_________________
Reply 14 of 20, by MiniMax
Rank Moderator
Moderator
Did you install the patch that came with the download?
_________________
Reply 15 of 20, by kardon
Patch now installed! Everything works so far. Thanks for all the help, guys.
Reply 16 of 20, by eL_PuSHeR
[MOVED]
Why everyone is posting DOSBox related stuff in the DOS (MS-DOS) forum?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 17 of 20, by Davros
maybe the forum should be called dos not dosbox otherwise its going to keep on happening
Reply 18 of 20, by wd
Rank DOSBox Author
DOSBox Author
??? That forum IS already called dos and not dosbox.
Reply 19 of 20, by leileilol
The game had its digital music streamed right out of SCORES.MIX in a proprietary, 22khz 4-bit mono format. Everything up to Tiberian Sun's expansion did this.
