DOSbox crashes
First post, by dbarton
I have been using DOSbox .73 wth my music sequencer. Has run great for years. I have not changed *anything* with Dosbox or the config files but have done things like update Windows itself.
As of today, every few minutes hitting a key in my Dos app will crash Dosbox competely. "DOSBox DOS Emulator has encountered a problem and needs to close. We are sorry for the inconvenience."
Any pointers to how I might begin to fix this? Any hints anywhere in the crash message?
Reply 1 of 10, by eL_PuSHeR
Have you tried a CLEAN INSTALLATION? Is everything else in working order in your PC?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 10, by dbarton
I have two separate versions of DOSbox installed, and they are both doing it, so I wonder if if can be related to video drivers or some conflict. Yes, otherwise, PC is running perfectly.
(.73, and an older specialized CVS)
I changed from overlay to opengl, and will run it more today to try an get it to fail. Open to any suggestions!
Reply 3 of 10, by eL_PuSHeR
Tried ddraw too? What videocard do you have? Do you have its drivers up to date?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 10, by dbarton
NVidia card with newest drivers. So far it didn't crash at all today.
Can overlay cause crashes?
That was just my wild guess.
Reply 5 of 10, by eL_PuSHeR
It's probably drivers or SDL implementation. If I recall correctly, Overlay was better suited for Ati cards. I am not sure. I usually have DOSBox set up for using ddraw too, and I have an Ati card.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 10, by dbarton
Is there anywhere in a wiki or whatever that explains what ddraw actually is, vs opengl etc in Dosbox?
I don't use Dosbox for gaming, so I'm looking for nicest text image, and especially not crashng. 😀
Reply 7 of 10, by eL_PuSHeR
Qbix, WD or someone else could explain that, but I think it's just a matter of choosing among different APIs to make graphic calls.
Overlay. I think it's commonly used for video.
ddraw. 2D accelerated functions.
OpenGL. A very popular 3D API.
And so on.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 8 of 10, by dbarton
So why use ddraw for non game apps? Better than opengl in some way?
Is it very likely this was my crashing issue?
It seems to have stopped, which really worries me, as I use Dosbox on stage for music performances. It has always been 100% reliable until the other day..
Reply 10 of 10, by gulikoza
Dosbox can crash if overlay lock fails (happens sometimes when screensaver activates for example). This is a bug in dosbox as it does not check whether overlay lock succeeded before writing to it.
edit: is it just me, or is this the same topic here? 😁
http://www.si-gamer.net/gulikoza
