First post, by szerooo
Hello
i use dosbox under xp sp2
usb optical mouse ....
and i dont know how to fix this problem i searched everywhere but i dont have any solve yet i want to ask u to help me on this
i want to play with warcraft 2 and with powball but my mouse is delaying and too fast i setup mouse sensitivity and cpu core cycles everything but nothings help ! Help me plz ! ty
fullscreen=false
fulldouble=false
fullresolution=640x480
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
language=
machine=vga
captures=capture
memsize=16
core=dynamic
cputype=auto
cycles=max
cycleup=500
cycledown=20
Reply 1 of 3, by IIGS_User
szerooo wrote:
fullscreen=false fulldouble=false ... cycledown=20 […]
fullscreen=false
fulldouble=false
cycledown=20
Bad text color selected in conclusion with background color.
Not good to read.
Klimawandel.
Reply 2 of 3, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
IF you own a logitech mouse you can change settings for it in the SetPoint software, especially the game awarness settings might be of help to play with. And do you have the problem in fullscreen as well?
Also your keyboard apparently has a caps lock problem that really needs to be fixed 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 3, by szerooo
jeah i have the same problem as well in full screen,-
but unfortunatally i cannot install this setpoint because
its my working pc so i cannot install anything it can be a solve
ty for the tipp but
when i am writing english i dont care about caps lock xD
only when if must 😁
