Turbo c++ GRAPHICS
First post, by luciano9
Hello!!!
I'm running Borland Turbo c++ with DosBOX and i have a big problem when i want to run a graphic program. I can't see anything when i run it.
I run the program, then it freez and can't do anything.
please help!
on windows XP i get NTVDM error 🙁
i don't know what to do..
Reply 1 of 6, by batracio
Your program freezes because of a bug in your source code and DosBox has nothing to do with that. We cannot help you very much without the source code, and even if you post it, this is not a programming board. I would use the free Borland C++ 5.5 compiler with the WinBGIm library in order to run the application in 32-bit mode and completely avoid both 16-bit mode and DosBox.
Reply 2 of 6, by luciano9
Ok thanks, btw.. my source code is fine, i run it on my university and its ok.
On windows XP i get NTVMD errors.... i don't know what is happening.
Thanks anyway.
Regards.
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
HOW do you run it there?
And next time what about posting some information about your system,
like the dosbox version and stuff?
Reply 4 of 6, by batracio
He probably runs it there in DOS real mode. Some universities have really old equipment.
Post your source code and I'll try to reproduce the problem.
Reply 5 of 6, by luciano9
The problem is on my PC. I have test it in another pc and works...
I'm trying to migrate to borland 5.5 but i get some errors with stdlib.h but its a good start.
thanks for all answers..
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
As noted above post the executable and/or source code, otherwise there's
not much to say about "that" problem.
