First post, by szekeres2009
Hello everyone, I'm experimenting with dosbox, and I was wondering if it is possibel to make a build out of the source like it is described in the dosbox wiki, but to use custom configuration file for the build, a custom icon and custom exe description, so there will be no need for shortcuts and bat files to run a game with custom config. The new build can only be used for that single game. Is is possible than how can I do that? I mean what should I do differently compared to the dosbox wiki build tutorial. Thnak you.
