First post, by TeaRex
Is this a known problem? I'll add more info if it isn't but I don't want to duplicate work that is already being done by others. It's an (almost) unmodified CVS (only thing non-standard in my CVS are the VGA font bitmaps, which IMHO would be very unlikely to cause this.) Build is entirely standard, ./autogen.sh, ./configure without options, make, make install
DOSBox version 0.73Copyright 2002-2009 DOSBox Team, published under GNU GPL.---CONFIG:Loading primary settings from config file dosbox.confMIDI:Opened device:noneUsing joystick MOSIC SPEED-LINK Competition Pro with 2 axes, 4 buttons and 0 hat(s)X Error of failed request: BadValue (integer parameter out of range for operation)Major opcode of failed request: 142 (MIT-SHM)Minor opcode of failed request: 3 (X_ShmPutImage)Value in failed request: 0x245Serial number of failed request: 105Current serial number in output stream: 106Segmentation fault (core dumped)
tearex
