Tie Fighter Collectors CD Issues
First post, by Keyser Soze
I'm new, and I have some problems with running TIECD on DOSbox. And I don't know where else to turn to. My mouse cursor goes all over the place, and while in flight my craft turns far up and to the right. The problem is most likely my Joystick. I am using a Saitek ST290 Pro, it did not require a CD to install the joystick, I only needed to plug it in. Any help will be greatly appreciated.
Reply 1 of 33, by swaaye
in the dosbox.conf at the joystick section change timed=true to false (or vice versa, I don't remember the default).
Reply 2 of 33, by Keyser Soze
Nope, didn't work.
Reply 3 of 33, by robertmo
use a fixed number of cycles
Reply 4 of 33, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There was also this joystick patch for the game
1+1=10
Reply 5 of 33, by Keyser Soze
Oh, you mean that thing that made it worse? I tried that and it didn't help. What's this about fixed cycles now?
Reply 6 of 33, by ripa
Tie Fighter CD works fine with variable cycles. Tie Fighter doesn't like extra axes, so use joysticktype=2axis. Timed= had to be set to the correct value too, but I can't remember whether the correct value for Tie Fighter was true or false. When you start the game, it asks you to calibrate the joystick. Make sure you do that.
Reply 7 of 33, by Keyser Soze
Ok that worked the first time. But after I turned the computer off and turned it back on the problem still persists.
Reply 8 of 33, by robertmo
ripa: how is it possible that tie fighter works with joystick and variable cycles? (all games i tried were decalibrating more the more cycles were changed)
Reply 9 of 33, by Qbix
Rank DOSBox Author
DOSBox Author
robertmo: timed=true can work with cycles=auto. timed=false tends to need fixed cycles counts.
(timed=true => use the system timer to decide when to release an axis)
(timed=false => a specific amount reads to decide when to release an axis)
Water flows down the stream
Reply 10 of 33, by robertmo
oh indeed (just checked), just the other way:
timed=false can work with cycles=auto. timed=true tends to need fixed cycles counts.
(timed=false => use the system timer to decide when to release an axis)
(timed=true => a specific amount reads to decide when to release an axis)
so how about setting timed=false as default cause right now it is true that is default
or actually renaming them would be better cause i think it is named the wrong way right now 😀
Reply 11 of 33, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There are two types of games - one counts the port reads until the axis bit flips. This type of games works with autocycles guessing when timed=false.
The other type reads the port now and then, and looks at the system timer when the axis bit flips. These games need timed=true with cycles guessing active.
1+1=10
Reply 12 of 33, by swaaye
I suggested changing timed= because that solved joystick problems with TIE Fighter DOS Collector's CD for me. Whenever I would look at a cap ship, the joystick would become quite erratic. Changing that setting fixed it up.
I'm at a loss if you're still having problems.
Reply 13 of 33, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Also note that you need to recalibrate the joystick in the game every time you change the timed= value.
1+1=10
Reply 14 of 33, by Keyser Soze
Yeah I don't get it. It worked the first time, but after trying it the next day, it just goes back to being crazy. And it's really begging to piss me off.
Reply 15 of 33, by Keyser Soze
Wait, is there an option in the config file called cycles?
Reply 16 of 33, by Keyser Soze
Any help, or thoughts, or ideas, no matter how crazy, would be most appreciated. This page has over 300 views, and nearly no responses. So let me make this clear. I WILL TRY ANYTHING!
Reply 17 of 33, by wd
Rank DOSBox Author
DOSBox Author
Yes.
Reply 18 of 33, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
What of the above suggestions have you tried and more importantly, HOW did you try them?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 19 of 33, by Keyser Soze
I have set the config settings to time=true by opening the file, I also set the joystick type to 2axis, but neither worked for more than one time. I tried the lucasarts cd patch, but that seemed to make it worse. I'm not sure what all this chatter is about the variable cycles, because there is no option under the joystick for me. I have also tried updating my joystick drivers.
