First post, by SkeeterUK
As title.
I have Dosbox 073 i think it is.
I have D-Fend Reloaded 090
Im trying to improve the gfx as i hate jaggies on the objects ingame, so i thought id try hq3 filter in dfendreloaded, but cant get it working. Also tryed lookin for direct3d support and how to use it, im clueless how to configure it and how to get it working in dfend reloaded and configure things.
The game works ok, just the gfx could use some smoothing to look nicer.
Please help me.
Reply 1 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
added forced to the scaler line
Water flows down the stream
Reply 2 of 11, by SkeeterUK
Reply 4 of 11, by SkeeterUK
How do i do this in dfend reloaded? Also will it just be the text and interface stuff smoothed or the 3d stuff in it so less jaggies?
Reply 5 of 11, by DosFreak
I don't know how to do that in DFend Reloaded. The above command is what you put in the dosbox.conf file so whatever .conf file your game uses in DFend Reloaded that is what you need to add to it.
There is no "3D Stuff" in DOSBox.
Make your games work offline
Reply 6 of 11, by SkeeterUK
The game uses 3d models, hence wanting em AA on em and hopefully i can find out how to get antriscopic filtering on them too.
Dfend is weird, it seems to do weird things for the games conf files.
Reply 7 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
game might use 3d models, but dosbox can't be aware of those as the game draws them itself on the screen.
Reply 8 of 11, by robertmo
i think it may be enough to set fullscreenresolution= your max resolution and output= opengl or ddraw
Reply 9 of 11, by SkeeterUK
Which is best ddraw, opengl?
Reply 11 of 11, by SkeeterUK
gtx 260, want the best visuals i can get but not sure on what filter to use, or render method in dosbox, tbh they all look the same when i try em, maybe im doing somit wrong.
