First post, by ableeker
I've been playing TR once again in glorious 3D mode without a Voodoo, and it's running beautifully, thanks to Glidos! Nothing worked, not even installing my old Voodoo 1 or 2 again, but Glidos, and it looks every bit as good (as far as I can remember, it's been a few years)! Soon after I had it working with Glidos, I registered, and I tell you, I'm impressed with Paul's work. I'm pretty sure a number of folks told us back then we could run Glide2x.dll using a Gilde wrapper, but it would be quite impossible to run Glide2x.ovl games! 😉
There's one thing, though, I used to play TR from my hard disk, not needing the CD at all, by using a patched Tomb.exe and Tombub.exe (these are all renamed 3dfx versions, of course). These versions used to work just fine, but they don't work with Glidos, so I had to dig up my original CD before I was able to play, and it's once again more or less permanently lodged in the drive (N). However, I'd rather not use the CD, not wanting to run the risk of damaging it! I know, I can make a copy, but I'd rather be able to do without it, and put the original away safely. I've copied all the files from the CD to the hard disks, and I could do without the music, I guess.
I used a patched Tomb.exe (1,140,735 bytes), and modified Glidos.ini like so:
Executable: C:\Tombraid\Tomb.exe
ExeSizes: 1140735
DosGraphics: Yes
ControlJudderFix: 1
Resolution: 2
FullScreen: Yes
ForcedTextureSmoothing: Yes
I modified the ExeSizes, and deleted entry CDCheckFile. This doesn't work. Glide Server starts, and when I click Start game, it loads VDMSound, and starts Tomb.exe, but instead of displaying the white splash screen (and starting the game), it justs shuts down to the desktop, and Glide Server displays no messages at all. This even happens if the CD is in the drive (N).
As a matter of fact, if I use the original Tomb.exe, the same thing happens if I leave my Zip drive (M) empty! Unfortunately, putting a Zip disk in the drive doesn't work for the patched exe. Actually, it would be nice if I didn't have to put in a Zip disk as well, them being rather fragile.
Does anybody have an idea how I can get the patched exes to run?
Thanks,
Aldo Bleeker
Reply 1 of 9, by Glidos
There are two versions of the 3dfx Tomb.exe. One tries to drive the hardware directly (which you don't have), and the other uses the Glide2x.ovl file. Glidos works only with the latter. Your patched one is probably based on the former.
For Tombub.exe there was only the second type. So you may do better there.
Reply 2 of 9, by ableeker
Thanks! That explains why one of the files I have (the one that's patched) has a file size of 1,140,735 bytes, while the other one (not patched) has a file size of 867,563 bytes. So I can understand why it doesn't work...
Today I've been trying to run a patched version of Tombraider 1 Unfinished Business in the same way, but I've had no success yet. The same thing happens: the unpatched version runs, but the patched version just drops back to the desktop, no messages whatsoever. As memory serves, the patched one used to work, in the days when I did have a Voodoo 1 and 2...
Oh, well, I guess I'll have to keep playing with the CD in the drive then...
Anybody any ideas?
Reply 3 of 9, by Glidos
The other thing I do sometimes is use Nero to make an image file and then use Nero's ImageDrive to make it look like a real CD, but then I can't get the background noises working.
Reply 4 of 9, by Nicht Sehr Gut
Originally posted by Glidos ...and then use Nero's ImageDrive to make it look like a real CD, but then I can't get the background noises working.
If you're using DaemonTools, try switching the "Analog audio" option on or off as appropriate. If your CD was "imaged" properly, the audio data should be playable.
Reply 5 of 9, by Glidos
The audio will be playable, but probably TR wont play it. If the TR CD isn't in the lowest-lettered removeable drive then TR seems to ignore the audio.
Reply 6 of 9, by ableeker
Thanks lads, great idea, should have thought of that myself! Anyway, I'm going to try that one soon. I'll see what Alcohol 120% can do, but like Glidos was saying, I was wondering if TR knows what CD station to use if there's more than one available. I seem to recall that a number of (older) games use the first available, especially when they're trying to play audio tracks. I might shuffle the drive letters around a bit to see if that works, but that's not really a satisfactory solution, I'm afraid.
It's probably best to copy the CD and store it in a safe place. It's not copy protected, is it? I mean, I know the exe does some sort of CD check, but a bit copy should work, shouldn't it?
BTW, does anybody know what exactly it is checking? CD title? File on CD? And if so, what file? And what CD in what drive (see above)?
Thanks!
Reply 7 of 9, by Nicht Sehr Gut
Originally posted by ableeker I'll see what Alcohol 120% can do,
The demo of DiscJuggler works very well for this. The demo forces a 10-second wait at the start and limits write-speed to 1x, but that's not a concern for using it with DaemonTools.
Right. TombRaider does this as well.
If the original game is coded that way, there's nothing you can really do unless you can get ahold of the source code. IOW, don't blame Paul for what the Eidos people did.
Probably is.
Don't know. An image created using DiscJuggler's default settings worked for me.
Reply 8 of 9, by ableeker
Thanks, good stuff.
I'm not blaming Paul in any way, nor was my remark intended as such. I like some of the "old" games, and am always on the lookout for great software at bargain prices. It's amazing how much cheaper software is if you wait half a year, or so! Anyway, I'm all too familiar with the problems (or should I say "challenges"?) we're faced when we try to run old games (and to a lesser extent other old software) under a modern OS. What I was saying was that I will try to run TR under XP, if possible without using the CD, and with the CD if not. I'll try a number of work-arounds to see if they work, and to find out how TR finds it's drive, including shuffling drive letters. And then, when I've satisfied my curiosity, I'll see what's the most convenient way for me to run TR.
In an ideal world I wouldn't need to any work-arounds or compromises, heck, I'd be running the D3D or OpenGL version of TR1 as released by Eidos, but I'd like to stress that's all they are, minor quibbles, caused by the fact that the programmers then didn't know what we know now. Can't really blame them for that, can we? I mean, Paul has impressed the pants off me by enabling me to play TR, a DOS Glide game, under XP. No way I'm going to criticise him for some minor inconveniences (not even caused by him) when he's already done the impossible, and even goes out of his way to work around the quibbles left!
Cheers.
Reply 9 of 9, by Nicht Sehr Gut
Originally posted by ableeker I'm not blaming Paul in any way, nor was my remark intended as such.
Sorry for the misunderstanding, then. There are plenty of people willing to blame Paul for things which he has no possible control.
Sure we can! *heh* Well, it wouldn't really be fair, I suppose.
I just wish that they had been a little more "forward-looking". I still think the "Age of Rifles" CD problem is ridiculous. Why on earth would you code your game to disable all audio if it detected a second CD-ROM?
