First post, by eksman
okay, so it works in everything apart from dosbox i tried it out in word, it worked fine, in my browser, worked fine, but for some reason when I try it out in dosbox it won't work, everything but that key works even '/' works but not '\' which makes it pretty hard when I'm trying to mount stuff.....
btw this is all on vista, trying to play daggerfall.....
thanks in advance......
Reply 1 of 2, by eL_PuSHeR
Did you read the readme file?
IIRC, / will serve you as well as \ for mounting things.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by ripa
If the readme doesn't help, read this post.
