S3 Savage 2000
Reply 21 of 112, by gravitone
The savage4 also support multi texturing, which it's predecessor the savage 3D did not. I know because I owned the latter back in the day and had slow performance in games like quake2.
Reply 22 of 112, by swaaye
That's correct. And then with Savage 2000 they doubled up the pipelines to basically double Savage 4.
Reply 23 of 112, by exxe
thanks for the links
but i cant get it working with my Diamond Stealth 540
i used:
Unreal (green pepper)
unreal patch226 final
w and w/o OMP-226
s3 reference drivers
latest Diamond drivers
S3 MeTaL 2.0.3.0
Unreal_S3TC_MapPack.7z
everytime i go to the advanced options to chose MeTaL i get the massage faild load
okay i can run it in software mode but this is not that what i want to do
Reply 24 of 112, by swaaye
Unreal, not UT? I haven't even tried Unreal with Metal yet. All I have is Unreal Gold and it doesn't seem to support Metal at all.
I suggest trying various versions of Metal and see what happens....
http://www.savagenews.com/drivers/s3/s3metal.php
The download links don't work anymore, but they did only a few days ago believe it or not. You can at least get the file names and driver version info though.
Reply 25 of 112, by swaaye
exxe, make sure that you are putting the Metal drivers in the Unreal/System folder. I noticed that the 2.0.3.0 Metal install puts them somewhere else and that won't work because the game doesn't find them. In fact I can't figure out where the 2.0.3.0 install puts the files or what their names even are! Diamond's 2.0.0.4 pack asks you where the UT system folder is (that pack won't work with Savage4 though).
Also, the Savage 2000 works fine on even a AGP 8x mobo as long as the 3 jumpers on the card are closed to enable AGP 4x mode instead of 2x. I now have it running on a nForce2 Ultra mobo with a Athlon XP 1800+.
And, I have to say that this card is probably at least as fast and equal quality as a Voodoo3 (maybe a 5) running Glide for UT99. Believe it or not! I will definitely say that Savage 2000 and Voodoo3/4/5 should have been the purchases of choice for the UT99 player. Poor clueless me with my G400 back then (yuck).
I also messed around a bit with the card's T&L. It can be enabled by the tweaker programs. I ran it with Quake 3 and some OpenGL benchmarks including GLExcess and NVIDIA Treemark. Quake 3 displays some geometry issues (for one, you can see inside of walls occasionally). Treemark shows that its T&L hardware is slower than the software capabilities of a Athlon XP 1800+ (unsurprisingly I guess.) T&L only "functions" in OpenGL though, no D3D, and it's flawed as shown by Q3. This is well known though.
Reply 26 of 112, by exxe
i only have the S3 MeTaL 2.0.3.0.exe from here
take a look on many old CDs but find nothing
Reply 27 of 112, by exxe
its alive!
someone send me s540xtreme_win9x_82021.exe
after install this driver and copy the metal.dll from it into unreals system folder its working under metal with S3TC 😁
edit
my testsystem
Asus P2B-LS, Pentium2 333MHz, 256MB System Memory and the Diamond Stealth 540
Reply 28 of 112, by swaaye
How well does Savage 4 run the game?
Reply 29 of 112, by exxe
yes, why?
Asus P2B-LS, Pentium2 333MHz, 256MB System Memory and the Diamond Stealth 540 pictures above
Reply 30 of 112, by swaaye
Actually I was asking if it runs smooth. How does it compare to a Voodoo3?
Reply 31 of 112, by gravitone
It even ran surprisingly well on my gainward savage 3d
Reply 32 of 112, by exxe
ups
its looks smooth, is there a way to show FPS whan playing?
dont try it with a Voodoo3 yet
Reply 33 of 112, by swaaye
For Unreal, I think you bring up the console (~) and type "timedemo 1". Something like that.
UT has a nice menu option that enables a realtime readout of framerate on the screen.
Reply 34 of 112, by exxe
timedemo 1 is right
Reply 35 of 112, by exxe
short test S540 vs 3dfx Voodoo3 2000 AGP
all FPS are from the 2nd loop
29.05 FPS V32k 1280x1024 glide
21.25 FPS S540 1024x768x16 metal
39.28 FPS V32k 1024x768 glide
25.39 FPS S540 800x600x32 metal
33.04 FPS S540 800x600x16 metal
47.23 FPS V32k 800x600 glide
43.90 FPS V32k 800x600 d3d
Reply 36 of 112, by swaaye
Well the V3 stomps the Savage4. I'm not sure if I expected that. I thought it might be more competitive with a V3 2000.
What CPU was used for those tests?
Reply 37 of 112, by exxe
should i use a faster or slower system?
Reply 38 of 112, by swaaye
use whatever you like. That CPU might be a limiter though and could be showing that the Voodoo3 is less CPU dependent.
Reply 39 of 112, by exxe
tried a Pentium3 700MHz on the same system
the voodoo runs a little bid faster but the S3 crashes after 5seconds 🙁
and bluescreens on the next test setup 😠
