Music quality
First post, by MadMonk
I think DosBox v. 0. 70 had better game music quality compared to v. 0. 73. For example in Duke Nukem II when using v. 0. 70 you can clearly hear the guitar parts during music unlike in v. 0. 73 they sounds quietly. How can I get the same music quality to v. 0. 73?
Reply 1 of 7, by lightmaster
editing your dosbox.conf
Reply 2 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
well the default volume level might have been lowered a bit.
So you could experiment with the mixer a bit.
other than that I would experiment with the oplemu setting
Water flows down the stream
Reply 3 of 7, by eL_PuSHeR
[Moved to DOSBox General]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 7, by robertmo
first of all choose general midi in game's setup
Reply 5 of 7, by MadMonk
I have following options on Sound Blaster section in DosBox v. 0. 73:
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=22050
On oplemu I've tried ''default'', ''compat'', ''fast'' and ''old'' and none of them helped.
Reply 6 of 7, by wd
Rank DOSBox Author
DOSBox Author
...and how did you configure the game??
Reply 7 of 7, by Roxor
MadMonk wrote:
I have following options on Sound Blaster section in DosBox v. 0. 73: […]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=22050
Seeing as Duke Nukem II uses the OPL2 for the music, you'll probably want to try upping the oplrate and the mixer rate to something higher. I use 96000 for everything, although my sound card does support up to twice that. Just keep in mind that higher mixing rates do use more CPU and your sound card will need to support whatever mixer rate you pick.
