First post, by link1200
i installed Lands of Lore yesterday and all went fine, tho i didnt have any idea the -t cdrom command existed so i had some problems at first but i got it runnign eventually, ran fine windowed but fucked up the colours in full screen, np for me.
the day after i try turn on mah pc, load up dosbox and try to start it. but it gives me this error:
Not Enough diskspace to run Lands of Lore( need 500000 bytes) **that while i have 100gb available-.-**
its the patched cd version and ive tried several things including reinstalling it(which does work normally, no whining about diskspace)
can any1 help me with this one?
im running win7 ultimate 64bit
Thanks 😀
Reply 1 of 6, by rcblanke
Go check the readme for 'freesize', link.
Reply 2 of 6, by link1200
i tried using freesize, same effect.
i made a screen of the commands i type in, might be a fault on my side
*See attachment, dont have photobucket account:)*
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
cdroms don't have any FREE space.
Reply 4 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
You need to install the game properly. Look up MiniMax's 60-second guide in the guides section.
Reply 5 of 6, by link1200
im slapped opf surprise of how easy that was rofl, its working(permanently i hope) thanks for the help
just as a litle offtopic thing btw, its not too much of a problem but i cant play in fullscreen, the game works but the colours go all weird, also it screws up my windows theme, changing it back to windows standard:o
any ideas?
Reply 6 of 6, by robertmo
choose different output type in dosbox's configuration
