First post, by mirzaz
Hi everybody!
Hope you will fint time to read this and help me.
I work with one program which is DOS based. I have aplication with .exe and files with .lnd extension. Normally in Win95 I doubleclick on file with .lnd extension and it starts in my app.
When tryed to start .lnd file from command line in DOSbox, I get message that xxxxxx.lnd is "invalid command bla-bla...".
How to start this program in DOSbox? 😕
Hope you understand my problem and you can help me with this.
Best regards
MirzaZ
MirzaZ
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
Is it a dos program or not?
Reply 2 of 7, by mirzaz
Yes it is DOS program.
Sorry, I tryed to sound smart there 😁
MirzaZ
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
If you are sure it's a dos executable, then just run it like any program in dosbox (that is the .exe, not the .lnd whatever that is).
Reply 4 of 7, by Kippesoep
Also, the .LND file is probably passed as a parameter. So rather than start FOO.EXE with BAR.LND by double-clicking on the BAR.LND file, you'd type "FOO BAR.LND" on the DOS prompt. (That is what Windows most likely does internally when you double-click on the .LND file).
My site: Ramblings on mostly tech stuff.
Reply 5 of 7, by mirzaz
Thanks a lot!
MirzaZ
Reply 7 of 7, by robertmo
i guess he used the .exe file 😉
