First post, by emote
Hello
I seem to have a problem with all LucasArts games (specifically XWing, DOTT etc) where the music is broken - it is trying to play but the wrong notes are playing and a strange din is the result, as if the orchestra is drunk.
All other games are fine.
My system is a p200 on a Gigabyte GA-5AX rev 4 (ALI chipset) and a Sound Blaster 16 - I have a CT2800 and CT2770, both do the same thing.
Does anyone know what this problem is?
Ta
Reply 1 of 3, by leileilol
Are you playing it in pure DOS, or through Windows using MPU-401 which in turn uses the MIDI Mapper that might be mapped to your SB16's FM synth?
Reply 2 of 3, by emote
It is pure DOS, v6.22. I just skipped the config.sys so nothing got loaded, and the music was still broken.
