First post, by Spawned
i ask if games ishar and stonekeep can be play with your VDMS2
thanks for reply with your command if possibility
regrets
spawned
regrets
spawned
AFAIK Stonekeep works properly on my machine running WinXP. As for Ishar, I don't know.
Originally posted by Spawned i ask if games ishar
Ishar? Don't know. Will check and see, then get back with you.
...and stonekeep can be play with your VDMS2
Stonekeep? Maybe...
hello , sorry, i don t more try , but will coming
and i want preview to you for ishar => it is Ishar III and NO ishar 1
thanks
Is English your native language?
The PC version of ISHAR III apparently "hits the hardware" in a very bad way.
Attempting to run it in XP resulted in
INTERRUPT 0DH, GENERAL PROTECTION FAULT possible illegal address error code = 0000 eax = 0000000C esi = 00000000 […]
error code = 0000
eax = 0000000C esi = 00000000 flags = 3206 ds = 01BF
ebx = 00000001 edi = 00015E10 eip = 0000DDD6 es = 01BF
ecx = 00000000 ebp = 00000004 cs = 01B7 fs = 0187
edx = 00018E00 esp = 00018DE4 ss = 01AF gs = 017F
It also kills DosBox, even the version in development (with protected mode support).
Don't know of a way at present to get it working in XP. At present, the only option I know of is to emulate the AGA Amiga version instead,
Any interresting error messages to tell me ?
(As I don't have the game)
Been fixing a lot of games lately so....
Water flows down the stream
yep, getting an error message i can't find anything on
cpu paging feature not supported
any ideas?
Hi
Ishar 3 works fine for me, I just cant save the game. As it asks for a disk in the A: drive any ideas??
