First post, by kalirion
I just got an Xbox 360 controller, and decided to see how well it would work with DOSBox. For the most part it works fine, aside from the seemingly non-existent deadzone. So I thought that for games where I don't want to accidentally press "up" when pushing the stick "left", mapping the D-Pad to the arrow keys would work great....
Unfortunately while the Mapper recognizes the D-Pad (as Hat 0), and appears to map correctly, after I save the settings the mapping does not take effect. As a test, I was able to map the X-axis of the first thumb stick to anything I tried, same for other joystick buttons. But the D-Pad mapping just doesn't take effect. Toggling "timed" between true and false doesn't help.
Does anyone know if this is a bug, or if I'm doing something wrong?
Thanks in advance!
