First post, by Therion
Hi
I've a strange issue with my favorite game Crusader: No Remorse on Dosbox 0.73 (Debian GNU/Linux).
It's from the english original CD (v 1.01), once I wanted to use the lift in the first level of the game (first lift you use) you can walk in but the game doesnt handle the exit point.
Nothing happens, you stay in that lift and can walk out of it again.
I can remember I've played this game in dosbox and it was working, dunno whats wrong now.
I'll provide the savegame Im using, maybe someone can test it...
756588c3b9cf0675551249da9c42e2e4 *SAVEGAME.1.bin (md5)
Reply 1 of 8, by Therion
Damn it didnt upload the savegame so again via bzip2 compressed:
97c77d4262e4a85a55e61e1250ba76b7 *SAVEGAME.1.bz2
Reply 2 of 8, by leileilol
Press the E key followed by Enter on the lift button to get the lift to lift.
Reply 3 of 8, by Therion
Hmm no that doesnt work to me, why "E"?
The Key to select buttons, switches etc. would be the S key but however it doesnt matter if I close the lift door or not.
Usually as far as I can remember once you step in the lift an animation takes over, walking the silencer into the lift and the door closes and lift begins to run.. then next level loads...
Reply 4 of 8, by Hater Depot
The end-of-level elevators don't work the same as the lifts throughout the levels.
Korea Beat -- my cool translation blog.
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
Just go back to the beam portal that takes you to the room with the big gun
(already destroyed), and return to the elevator. Worked then, maybe a game bug.
(opens with S + return, then just move in).
Reply 7 of 8, by Therion
Hey
Wow thanks so much, you saved the night. 😀
PS.: no didnt patch it.
Reply 8 of 8, by wd
Rank DOSBox Author
DOSBox Author
You destroyed my night, playing crusader now, thanks... 😀
