First post, by bengraylight
Sorry about the double post in the DOS forum...
DOSBOX allowed my old friend and I to play Warlords 1 again. THANK YOU!
Problem is, he lives 14 hours away now. So... I set up a Windows Vista VPN client with LogMeIn and it's great. He can connect to my machine (from his Windows Vista box) and I can run DOSBOX and run Warlords 1.
The problem is, when he tries to control the mouse in Warlords 1, it acts real crazy and sticks to the sides of the screen and it's not playable.
Does anyone have a suggestion as to how I can get his mouse control to work with my DOSBOX?
Thanks!
Reply 1 of 2, by robertmo
maybe its a joystick problem (disconnect joystick or disable it in dosbox's configuration file, or set different timed= setting in that file)
remove the other post
Reply 2 of 2, by ADDiCT
Double posting is considered very bad style by the way, and won't give you more attention.
