wd wrote:In your first posting you say it doesn't advance after the menu screen
please read again carefully, i said `it only goes into the main menu and then the first screen of the game`
ripsaw8080 wrote:what is odd is that the original version of the game will not start up in DOSBox at all because of the copy protection; which does not fit with the poster's descriptions of not being able to get past certain screens...
it doesn't start via dc.exe, but when you launch dcovl.com it does .. but yes, most probably dc.exe is needed and it has that copy protection
ripsaw8080 wrote:DOSBox does not support physical copy protection on floppy disks (erroneous sector ID, CRC errors, weak bits, tracks with different formats, etc.), and standard image formats don't contain the necessary extra data (teledisk or so might). Anyway, a crack is needed to play the game in DOSBox.
allright, thanks, i guess i need to find a crack for it. or put the image on a real physical floppy drive and use that in dosbox
or maybe wait.. do you think it would work if i mounted the image in a virtual floppy drive that supports copy protection (unlike dosbox) and then mount the virtual drive as floppy in dosbox, could that work? because that image is supposed to be 1:1 image containing all the data along with copy protection
