Booter games compatibility overview
Having problems with a specific game or application? Post your problems here!
Re: Booter games compatibility overview
Postby h-a-l-9000 » 2010-5-21 @ 19:46
Got no mainboard for the 8086 and 8018x CPUs :(
1+1=10
h-a-l-9000
DOSBox Author
Postby angrylion » 2010-5-21 @ 19:56
Qbix wrote:no, but a reference manual alone isn't enough for us to change things.
Not only 4 manuals in this case, but also the observation that the game runs on 8088 and doesn't run on 286, which fits the information in manuals very well.
angrylion
Postby wd » 2010-5-21 @ 19:57
which documented that 286's divide overflow interrupt behaves not like 8086/8's as far back as in 1986
Does it say anything more than that the 286 has different IP handling for the exception case?
wd
DOSBox Author
Postby angrylion » 2010-5-21 @ 20:04
Nope, just that.
Code: Select all
Any interrupt on the 80286 will always leave the saved CS:IP value pointing at the beginning of the instruction that failed (including prefixes). On the 8086, the CS:IP value saved for a divide exception points at the next
instruction.
Here's another notable discrepancy, by the way:
Code: Select all
The 80286 pushes a different value on the stack for PUSH SP than the 8086/8088. The 80286 pushes the value of SP before SP is incremented as part of the push operation; the 8086/8088 pushes the value of SP after it is incremented.
angrylion
Postby wd » 2010-5-21 @ 20:25
Both are well known/can be found on various bug lists (didn't know they were
officially documented), but they are irrelevant for this issue.
item11 in
http://www.logix.cz/michal/doc/i386/chp14-07.htm
is the difference causing the bad behaviour, which was verified on 8088
compared to the 80286/dosbox behaviour.
wd
DOSBox Author
Postby angrylion » 2010-5-21 @ 20:32
wd wrote:Both are well known/can be found on various bug lists (didn't know they were
item11 in
This list is chapter 14.7 of the official 386 PRM. Item 11 is present in both 386 PRM and 286 PRM. Again, manuals say it's a difference between 8086/8 and 286+.
angrylion
Postby wd » 2010-5-21 @ 20:47
Right and unless you actually test this you won't know if 8086 is closer to
80286 or 8088 for this feature. Don't know why you insist on this being
a so interesting thing, but just go ahead and verify/falsify it, then post the
results so they can be ignored because of missing relevance.
wd
DOSBox Author
Postby angrylion » 2010-5-21 @ 20:55
wd wrote:Right and unless you actually test this you won't know if 8086 is closer to 80286 or 8088 for this feature. Don't know why you insist on this being a so interesting thing, but just go ahead and verify/falsify it, then post the results so they can be ignored because of missing relevance.
Thank you for your kind proposal, and no, I'm not going to retest what was tested by Intel engineers in 1986, especially given the lack of contradictory data.
angrylion
Postby wd » 2010-5-21 @ 20:59
Ok.
wd
DOSBox Author
Previous
Return to DOSBox Games/Apps
Who is online
Users browsing this forum: robanator2018 and 3 guests
