Adlib and MIDI
First post, by jez
A couple of things:
1) What happened to my Adlib page on the wiki?! It used to be at http://dosbox.sourceforge.net/wiki/index.php?page=Adlib, as linked to on this thread. Looks like it's just been deleted. Took me ages, that page. 😢
2) I've been adding in some extra info for the MIDI config values on the wiki, here. As you can see I'm not 100% sure on the difference between the 'coreaudio' and 'coremidi' options, though I think they're both to be used on MacOS X. Could anybody fill me in?
== Jez ==
Reply 1 of 9, by DrLex
Yes, both CoreAudio and CoreMIDI are OS X frameworks. The difference between both is that CoreAudio will render the music through the built-in OS X synthesizer, and CoreMIDI will route MIDI commands to any device that has been configured in Audio MIDI Setup (if any).
Reply 3 of 9, by jez
h-a-l-9000 wrote:
Did your Adlib article by any chance end up in there?
http://www.dosbox.com/wiki/Sound
Unfortunately not. It has some stuff on Adlib but nothing like the full article I remember writing back then... 🙁
== Jez ==
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
The data of the old wiki should still be there.
Just the redirect messes up your way to access it.
(at least that it is what I think)
Fixing access to the old wiki is on my todo list.
Water flows down the stream
Reply 5 of 9, by jez
Oh right... any reason you didn't transfer the old wiki data to the new wiki?
== Jez ==
Reply 6 of 9, by wd
Rank DOSBox Author
DOSBox Author
Reply 7 of 9, by jez
Yeah, accessing the old wiki isn't the same thing as copying its data across to the new one...
== Jez ==
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Same reason obviously.
Reply 9 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
different wiki software
so each page must copied manually..
Got bored after copying the most important pages.
