First post, by guruNS
Mac OS X 10.5.8
Running DosBox in Windows XP on windows parallel and on MAC OS X
3GB RAM
2.33 GHz Intel Core 2 Duo
ATI Radeon X1600 graphics card
DosBox 0.73
I have solved the eariler problem with SuperStar Wars for PC. I have a new problem in DosBox. When I connect the Steel Series 1GC usb controller to my Mac and turn on SuperStar Wars for PC the characters (Luke, etc.) continuously ducks as if down on the D-Pad is being pressed. I lay the usb joystick down and do not touch it and it still acts as if down on the D-PAD is being pressed. It works fine using the keyboard I just want to use my usb controller. I also tried Shinobi and Prince of Persia and it does it on those games also.
What is causing this?
Have anyone encountered this issue and resolved it?
If so, What did you do to correct this?
Thanks
