Help I can't get dosbox gamelauncher to work
First post, by maxrebo
I followed the steps and it can't find java and I have it in the folder.
Can you give me the steps on what I need to do to get it to work.I am not good at computers so if I was supposed to something else to get it to work please explain it.
Reply 1 of 25, by SKARDAVNELNATE
You have what in which folder?
Install Java
Extract DBGL somewhere
Run dbgl.cmd
Reply 2 of 25, by maxrebo
my File structure is like this
C:\Dosbox Game Launcher inside their I put java.exe and javaw.exe and ran dbgl.cmd and it said java is not a internal or external command.Java is installed in C:\Program Files (x86)\Java
Reply 3 of 25, by leileilol
Get the runtime!
Debian's fucked
Reply 4 of 25, by maxrebo
I already I have it but do I install it again into that folder.
Reply 5 of 25, by SKARDAVNELNATE
No. It normally installs to C:\Program Files\Java\jre6
Reply 6 of 25, by maxrebo
It is installed there and up to date.
Reply 7 of 25, by maxrebo
I have 64 bit windows 7 but I downloaded the 64-bit version.
Reply 8 of 25, by SKARDAVNELNATE
dbgl.jar should be an Executable Jar File.
If it isn't hit properties.
Opens with: Change.
javaw.exe" -jar "%1" %*
Reply 9 of 25, by maxrebo
What about I start from square 1,delete everything,reinstall and then you tell me everything I need to do or to get in running.It says executable jar file for dbgl.jar.
Reply 10 of 25, by SKARDAVNELNATE
Uninstall Java
Install Java
Run dbgl.cmd
Reply 11 of 25, by maxrebo
Were should I install both java and dbgl. I am running 64 bit windows 7
Reply 12 of 25, by maxrebo
I was originally getting the error, 'java' not a recognized internal or external command blah blah.I looked that up and did the environmental variables path stuff and I don't get that anymore.Now its says unable to run jarfile dbgl.jar.What do I do to fix this by the way I am running it has an administrator.
Reply 13 of 25, by SKARDAVNELNATE
I let Java install the way it wants without changing anything.
You can extract DBGL where ever.
I place it in C:\Program Files\DBGL and make a dbgl.cmd shortcut that uses the DOSBox.exe icon.
Reply 14 of 25, by maxrebo
What should I do about that error.
Reply 15 of 25, by rcblanke
maxrebo, maybe try the DBGL jar wrapper I made; just put it in your DBGL directory and run it.
Please let me know if this tool solves the problem.
Reply 16 of 25, by maxrebo
No luck,I extracted it to my folder and when I click it nothing.Yet when I copied it and put it on the desktop it said unable to access jar file location of C:\launch.exe\dbgl.jar
Reply 17 of 25, by maxrebo
Then why I copied dbgl into that path I get the error about couldn't find main class and a bunch of stuff I couldn't understand.
Reply 18 of 25, by maxrebo
Besides install dbgl am I supposed to do anything special with java other than install it or is anything supposed to be in a special directory.
Reply 19 of 25, by rcblanke
maxrebo, please make sure you're using the DBGL version appropriate for your system; when you've installed Java 64-bit, you should also use the DBGL 64-bit version.
Your problem report is rather chaotic; please attach a picture showing your DBGL directory, maybe that brings more clearity to the issue.
