First post, by silvercoon
try this
put the NOCTIS folder in the C:\ folder
mount c C:\Noctis
C:
CD MODULES
NOCTIS
that's the easy part.
next, depending on your system, you may have to set CYCLES=MAX.
OUTPUT=SURFACE should work.
there is no sound, so I didn't worry about those settings
I usually set CPU=DYNAMIC
if you know haw to work with *.CFG files, create one and
make these changes to it. I usually created shortcuts to both the emu and the CFG file and put them both on my desktop. then made specific changes for the game I wanted to play. Save/close, start DOSBox, and if everything is just so, the game should start right up. print out the docs, too, if you can. check the MANUAL folder. hope!
"I have super powers, too. I can blind people with the glare off my forehead. UUHHH!'
