Settings only GUI panel?
First post, by Mark2000
I was reading through the wishlists and was recalling debates about this years ago. I personally like navigating DOS as part of the experience. So I would lean on the side of not including a GUI. Third parties seem to be doing a fine job of it.
But, honestly, the config file is a mess to navigate and shows up in different places with each version of Dosbox and on different OSes. It would be nice to have a preference panel that would make all that stuff into a bunch of check boxes. Its not a full GUI, but just a place to tweak global settings without having to edit a hidden text file.
Reply 1 of 19, by wd
Rank DOSBox Author
DOSBox Author
Frontends do that.
Reply 2 of 19, by DosFreak
There's no need to worry about different versions of DOSBox, just the latest. As for that one it dumps the config file where it should be in home or profile folder.
Linux
\Home\Username\.dosbox
9x-NT4
C:\Windows\Profiles\somewhere under here
C:\winnt\Profiles\somewhere under here
2000-XP-2003
C:\Documents and Settings\Username\Local Settings\DosBox
Vista-2008-7-2008R2
C:\Users\Username\Appdata\Local\DOSBox
Which under Windows can be accessed using the handy dandy "DOSBox Options" shortcut so you don't have to remember the path.
Make your games work offline
Reply 3 of 19, by Mark2000
Yes, but why? The question is why should even the most hard core user have to search for a config file and edit it by hand? Why is a settings panel so offensive? You know, DOS software had them. Most games required an install program before launch. Are you saying DOSBox needs to be more primitive than software from 1987?
Reply 5 of 19, by Mark2000
Hey, you're witty! How's that working out for you?
Reply 6 of 19, by dvwjr
Hard core users by definition edit config files by 'hand'.
Gee, you are only the seventy-billionth person to make such an observation about DOSBox. 😜 However, several coders have already obviated your request by actually producing exactly what you requested before you even asked!
Guess you missed the "Frontend" comment above.
What you want DOSBox to do is already done by numerous GUI front-ends for DOSBox. Try looking here to your heart's content...
dvwjr
Reply 7 of 19, by collector
Not all install programs at that time had a GUI. Sierra had text based installers up to around 1990. Some reasons that many prefer doing it by hand is that it is simply quicker and easier. On top of that, there are usually only a few changes from default that you will ever use for any one given game. You can use an custom config file for that game that only has the settings that vary from the defaults that you want. The game will use the DOSBox defaults for everything else.
Reply 8 of 19, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
[quoteBut, honestly, the config file is a mess to navigate[/quote]
How so? It's a text file you scroll up and down...
How dare they make the OS' different to each other?
Anyway it has been tried to integrate something like this into Dosbox and both authors didn'T finish it, instead never came back...
So, yes, there are frontends...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 19, by Mark2000
Yes, moving the config file every version is pretty much an attempt to drive off all but the most hard core users. It's amazing how many programmers complain about bad software when a command in the drop down menus isn't where it should be and this piece of crap moves its entire settings structure to a different place with each iteration. I had a config file that was fine where it was in the same folder as dosbox, upgraded, attempted to continue editing the file as usual. Found that changes had no effect. Had to go rummaging through the damn wiki to see it had been recreated elsewhere.
Front ends really don't cut it mostly because they act as game launchers. At least all the ones on the Mac do. I don't want a game launcher with a need to reset everything for each game. I just want to be able to set one attrib here and there easily. 21st century style.
And yes, it is difficult to have to scroll through heaps of text options and # comment lines and then set options where some are "yes/no" and some are "true/false". It's all such bullshit for the sake of it. I can see why the author's gave up. They, and most everyone here are ninnies when it comes to any kind of usability. Instead of sitting with your thumbs up your asses saying "this is not important to us gods", get someone who is versed in simple human interface stuff - like me, I'm a frakking web designer/animator/ui creator - who would work for free and take their advice.
No, I can't code it myself. That's not my thing. But I can certainly advise, do mock ups, and create elements all for the love of the app. If you all weren't so hostile and silly. But do continue alienating people and keep making a shit product that we never gain real wide spread usage beyond uber geeks.
Reply 10 of 19, by Mark2000
BTW, I also wanted to mention how hilarious it is that one your arguments is "don't you think a million people have said the same thing before you". Just shows how out of touch you are. A million people are saying it because its an obvious flaw. After that no other argument makes any difference. Makes me wonder if a bunch of people walked up to you and told you you had a bloody nose if you would continue to disagree until you had bled to death.
Reply 11 of 19, by leileilol
If that were actually true, I wouldn't have ever imagined the world would have over 10,000,000 uber geeks to get it!
Just use a frontend. I use DBGL. It's cross platform java, maybe you will like it. The end.
By the way, this is Free Software for there is no such thing as entitlement or warranty. The developers don't owe you anything. It is a hobby project.
Debian's fucked
Reply 12 of 19, by rfnagel
The solution is quite brainlessly simple. Head to EBay and buy yourself a shiny new 386 or 486 class machine... PROBLEM SOLVED!.
Oh, but waitaminute, you'll STILL have to configure the hardware and edit cryptic things such as AUTOEXEC.BAT and CONFIG.SYS files to 'tweak' it up.
Sorry, I wasn't thinking... my bad.
(edit) Oh, and if you wish to bitch about "shit products", I'd suggest you head over to some of Mickey$oft's forums :whap:
[rant]
# Lines in this section will be run at shutdown.
rantmode=off
shutyertrap=true
...and to the world (and DB authors).... DOSBox ROCKS! 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 13 of 19, by Dominus
DOSBox Moderator
Please stop telling him to shut up. I'm enjoying this far too much. Is it yearly or half a year that someone who knows it so much better shows up to bi... aehm I mean, shows up to give such even tempered advice?
Reply 14 of 19, by Kippesoep
I'm still around, Dominus. And actually still working on it too, though progress has been slow due to my new and rather busy day job. On the plus side, vacation time is coming up soon 😁
Yes, tomorrow it'll be a year since my last post about it, but there will be an update soon. http://www.shdon.com/blog/tag:dosbox
My site: Ramblings on mostly tech stuff.
Reply 15 of 19, by rcblanke
Mark2000 wrote:
...Front ends really don't cut it...
Constructive feedback/comments/suggestions are always welcome.
Reply 16 of 19, by IIGS_User
I think it's about some general settings, which my frontend really lost with version 2.0, on some frontends known as Template.
Klimawandel.
Reply 17 of 19, by ripa
Wasn't someone working on a cross-platform gui? Last time I browsed Dosbox's source I saw some kind of a GUI subtree.
Reply 19 of 19, by Dominus
DOSBox Moderator
Great to hear something from you on this subject...
If you get this a bit further I'd realy like to see a patch for it, since I switched to OS X and thus a windows binary is nothing for me anymore 😀
Anyway, knowing that you are still on it makes me happy enough...
