N I T E M A R E - 3 D and 0.74
First post, by trebor
After ~7 minutes of playing, DOSBox crashes, the system returns to the Windows desktop with no error message(s) present. OS = XP SP3
For those unfamiliar with the game:
http://www.dgray.com/n3dpage.htm
http://www.mobygames.com/game/nitemare-3d
http://en.wikipedia.org/wiki/Nitemare_3D
Reply 1 of 21, by Harekiet
Rank DOSBox Author
DOSBox Author
DOSBox realizes that the game is too horrible to continue, sorry.
Reply 2 of 21, by IIGS_User
We have to remember that cool proverb.
Klimawandel.
Reply 3 of 21, by trebor
Very funny. Seriously, any thoughts as to what would cause the game to run fine for ~7 minutes and then suddenly crash?
Where or what you are doing in the game does not matter. DOSBox crashes with no explanation or error window.
Reply 4 of 21, by wd
Rank DOSBox Author
DOSBox Author
There's no 7minutes timer in dosbox. So your best bet is to play with the
settings (oh indeed mentioned in the README) like xms/ems and core stuff.
Reply 6 of 21, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Are you sure there's no message in the console output just before DOSBox closes? An "Exit to error" message usually appears in the console window if it is open; or if you run DOSBox with the -noconsole parameter, you can look in the stdout.txt file after it has closed.
Reply 7 of 21, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Is it a regression in 0.74?
1+1=10
Reply 8 of 21, by Qbix
Rank DOSBox Author
DOSBox Author
well the game worked in an earlier version of dosbox. I completed several levels.
but I don't recall which version of DOSBox I used.
Water flows down the stream
Reply 9 of 21, by redblade7
Hey don't diss Hugo or the doggy will eat you
-redblade7
Rogue Central @ coredumpcentral.org
Reply 10 of 21, by leileilol
1.0 Hugo or 2.0 Hugo?
Debian's fucked
Reply 11 of 21, by redblade7
The dog was in Hugo's House of Horrors (the first one), not sure about Whodunit (2) or Jungle of Doom (3). When you went into a room with him the computer would beep "How Much Is That Doggy In The Window" and he would eat you unless you did something, I forget what
I never got into Nitemare 3D but remember the graphics being really crappy
-redblade7
Reply 12 of 21, by SKARDAVNELNATE
Throw pork chop.
Reply 13 of 21, by sliderider
+1
Reply 14 of 21, by filipetolhuizen
Maybe setting the core type to full or simple instead of dynamic? There is also a Windows 3.1 version of the game which runs great under Windows XP (and probably under Vista/7). It may have the sorriest graphics, but it's the best fun ever.
Reply 15 of 21, by collector
Not an option for some Vista users and many Win7 users. Sales of 64-bit Win7 comprise about half of the Win 7 market. Setting up Win3x in DOSBox or a VM seems like too much work for this game.
Reply 16 of 21, by filipetolhuizen
Yes, unfortunately it'll not work under any 64-bits Windows. But it'll work fine for the topic author.
Reply 17 of 21, by nikiniki
I reached to level 3 with no problem with dosbox 0.74. It didn't crash to me.
Reply 18 of 21, by filipetolhuizen
It's probably that Core type thing.
Reply 19 of 21, by nikiniki
Nitemare 3d is still better than Daikatana.
In Daikatana, you can't save anywhere while Nitemare 3d can.
