First post, by guest_ds
Hi guys, I just installed Rayman Learning Center Vol. 1 using this video on Youtube as a guide: http://www.youtube.com/watch?v=H0vkOaX-W-g
Since I'm REALLY unfamiliar with computers, I've decided to use Belarc Advisor.
1.?
2. 2.00 gigahertz AMD Athlon 64 X2 Dual Core
256 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded
3. ?
4. NVIDIA GeForce 6150SE nForce 430 [Display adapter]
Samsung SyncMaster [Monitor] (19.1"vis, s/n H9FQ859659, August 2008)
5. Realtek High Definition Audio
6. Windows Vista Home Premium Service Pack 2 (build 6002)
7. Rayman Learning Center Volume 1
8. After installation, it gives me this problem:
CD ROM's initialization.
CD ROM drive found on E:
Please insert Rayman's cdrom.
- If rayman can not find disk, press ESC, and rerun Rayman.
- If you want to try Rayman in limited mode, press SPACE.
I've tried pressing ESC and Space, and it didn't do anything. I reinstalled the game, but the second time, the sound wouldn't work.
9. Always whenever I run the batch file on the computer, or press play using the CD's install file.
10. I think the sound card used was Roland 10 or something. I could check again soon if needed.
11. Unsure.
12. DOSBox 0.74.
13. Reinstallation. Messed up the sound though. This is what I typed on DOSBox by the way:
mount e e:/ -t cdrom
mount c c:\rlc1
dir
e:
dir
install Thank you in advance.
