Hi!
Use DB MegaBuild 3 for winword over windows 3.11!
I want to share here my experiment results on WinWord compatibility.
I had a goal to run WinWord 2.0 and WinWord 6.0 simultaneously.
1. DOSBox v0.74 is OK with WinWord 2.0, but doesn't allow WinWord 6.0. The last one requires "share.exe", but it is incompatible with DOSBox v0.74 and is not supported.
2. DOSBox v0.74 + fakeshar.com is PERFECT with WinWord 6.0! Find fakeshar.com in "Windows 3.1x DOSBox Guide" by Dominus. This utility should be executed before starting windows 3.11.
3. DOSBox v0.72 is OK with WinWord 6.0, but WinWord 2.0 stucks while starting macros.
4. DB MegaBuild 3 is OK with both WinWord 2.0 and WinWord 6.0.
