First post, by trebor
Both games provide better (enhanced) graphics and sound than CGA when played on a PCJR.
However, emulation of the pcjr in DOSBOX results in the following:
Boulder Dash = Just CGA graphics and PC speaker sound.
Boulder Dash II = B&W graphics and PC speaker sound.
For reference please see here:
http://www.mobygames.com/game/pc-booter/bould … eShotId,383720/
& here:
http://www.oldskool.org/shrines/pcjr_tandy/#hidden
Reply 2 of 9, by sliderider
Well, PC jr. never was 100% compatible with the PC so I would expect there would be problems using functions unique to the Jr. such as the extended graphics modes. I would have to guess that more PC jr. compatibility than what currently exists would have to be programmed in to fix the problem you are experiencing.
Reply 3 of 9, by Servo
Also, if you're using the cracked Super BoulderDash (includes BoulderDash 1 and 2) version that seems to be common there's apparently something wrong with it (at least the copy I have); even on real hardware it doesn't work correctly with PCjr graphics and sound while the original disk works fine.
Reply 4 of 9, by trebor
I'm not, but thanks for the information.
The "original disk work fine" comment I presume is still in utlization with a 'real PCjr hardware' and not DOSBox emulation of the system.
Reply 5 of 9, by Servo
Correct. It's a bootable disk, so I don't know of a way to use the real disk with DOSBox.
Reply 7 of 9, by Servo
wd wrote:
What do you mean? Same way as other booters.
Most likely it's just that I don't know what I'm doing, but I haven't figured out the command to boot a real disk with dosbox. I'm assuming I need to use the mount and/or boot command, but I haven't figured out the right syntax yet.
