First post, by GordonXFreeman
How does one change a floppy image during an install of an application?
I have originally did imgmount a c:\disk01.ima and during the install it wants disk 2.
Help!
Thanks!
Reply 2 of 4, by GordonXFreeman
Running Windows 7 64-bit
That application wont run...
thanks for trying....
Reply 3 of 4, by ADDiCT
I didn't try that VFD thingy because I wouldn't want to install a driver on my system for a function I seldom need/use (I like to keep my system as "clean" as possible). I guess you could install VFD by enabling "test mode" in Win 7 which allows you to install unsigned drivers. I've been successfully using BOCHS or VMWare to install those multi-disk games that can't be installed in DOSBox.
Btw, the "imgmount" command supports mounting more than one medium and cycling via a hotkey, though I don't know if this works with floppy images. You'll find info about the syntax in the DOSBox manual.
