Weird AWE64 Gold problem
First post, by Spaz
I have a weird issue with my Retro PC. It's been working fine for years, but suddenly all adlib sounds are very weak.
I noticed this today when I played Commander Keen 4. The music/sound was barely audible. After some troubleshooting I've found out this low-volume issue affects all games using adlib sounds.
e.g, if I run Pinball Fantasies in Sound Blaster 16 mode, all is well. If I select adlib the 'low-volume' issue occurs.
I suspect an On-board amplifier has stopped working.
Does the AWE64 Gold have a separate Adlib/FM synthesis chip that, if defective, can cause this issue?
Reply 1 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Have you tried the mixer utility?
1+1=10
Reply 2 of 4, by Spaz
Yes, I've checked the mixer utility. Sound level is properly adjusted. (I haven't made any changes to the system from yesterday)
Reply 3 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Well does it respond if you change its volume?
1+1=10
Reply 4 of 4, by Spaz
The problem was with the ctmix.cfg file. For some reason it was read-only with low midi volume setting.
Things are working as normal now 😀
