Quest for Glory 4 1/2
First post, by BDNate
I remember playing this parody game when it first came out a while ago but I just recently tried to play it again using a current version of dosbox and it doesnt seem to want to start. I'm not sure if anyone else has played this game but its a pretty funny parody of the quest for glory series (my favorite adventure game series). Any suggestions would be great, thanks for the hard work dosbox guys.
AMD Phenom 9650 Quad-Core
Nvidia GeForce 260 GTX
ECS A780GM-A Ultra Motherboard
4gb corsair 6400C5PRO
Windows 7 Ultimate
Reply 1 of 12, by Reckless
It's a AGS adventure and as such isn't it limited to Windows only?
Reply 2 of 12, by BDNate
There are 2 versions, the windows version hasn't worked in a while, at least for me, i figure the dos version is the best bet. I attached a pic of the message I get when i try to execute it if this helps. Thanks.
Windows 7 Ultimate
Reply 3 of 12, by wd
Rank DOSBox Author
DOSBox Author
Does that really work under real DOS?
Reply 4 of 12, by Jorpho
It's been a while since I poked at it, but as I recall you can download the Windows version of AGS 2.23, point it at the DOS executable for QFG 4.5, and be on your way.
I also recall that the game is apparently a little bit broken even when you can get it running correctly.
Reply 5 of 12, by keropi
give me a DOS version download link and I will try it for you on a real machine 😀
Reply 7 of 12, by keropi
it just crashes with the exact same errors like DOSbox. All are the same, numbers , addresses etc...
Reply 8 of 12, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Tried different CPU types and core= in DOSBox?
1+1=10
Reply 9 of 12, by Jorpho
I think I see the problem. You downloaded cwsdpmi like the game told you to, right? The first Google hit for cwsdpmi (after Wikipedia) is for http://www.dbit.com/pub/cwsdpmi/ . That is version 4. I get the crash in DOSBox with that version too.
Version 5 works, and so does version 7. The link to the binary distribution is right at the top of the page.
http://homer.rice.edu/~sandmann/cwsdpmi/index.html
(By the way, it takes quite a while to start up.)
Reply 10 of 12, by keropi
there is no cwsdpmi with the game and it did not complain about it when I run it...
Reply 11 of 12, by Jorpho
You must have it in your PATH somewhere on your DOS machine, then.
