DOSBOX stuck my windows please help
Reply 20 of 35, by dj_anubis
MY HARDWARE IS FINE ITS A NEW COMPUTER WITH NEW VIDEO CARD COMMON I PLAY GTA 4 REAL SMOOTH ITS NOT HARDWARE
Reply 21 of 35, by wd
Rank DOSBox Author
DOSBox Author
Your computer crashes.
Reply 22 of 35, by dj_anubis
look if it was a hardware issue, then my computer would crash in other events beside dosbox, it would crash in 3d games, it would crash randomaly, it would crash on dosbox itself
The thing is it crashes ONLY AND WHEN I SAY ONLY I MEAN ONLY when i try to quit dosbox, in my opinion it mught be software issie I really dont know
Reply 23 of 35, by wd
Rank DOSBox Author
DOSBox Author
Which can easiest be tested by stress testing, and not some 3d games that may or may not exercise the relevant parts of your system.
Software "issies", assuming you're on windows since you failed to post that, can be checked by various means, DOSFreak already posted about it.
So read the thread instead of ignoring what people post.
Reply 24 of 35, by dj_anubis
I made print screen while it stuck in window mode here is what i saw on the screen anyone know how to solve it?
Reply 25 of 35, by wd
Rank DOSBox Author
DOSBox Author
That should be in the gfx driver/directx area, but yeah, you neither read
replies of other people, nor check your system, so who cares.
Reply 26 of 35, by dj_anubis
I tried to work in SAFE MODE it works fin and not stuck, as I said before there I cant indicate when its happen sometimes it happends sometime not, anyway after trying 30 minutes it worked fine
NO PROBLEMS IN SAFE MODE
so what should I do now to solve this problem?
I really need your help...
Reply 27 of 35, by dj_anubis
also Iwhen i try it on dosbox 0.63 t works great and didn`t crash all day, but the problem is i can`t figure how to mount CD IMAGE on 0.63 and how to disable 0.63 from detecting my joysticks
help...
Reply 28 of 35, by wd
Rank DOSBox Author
DOSBox Author
That either some driver is broken in its non-safemode usage, or some custom (autorun) application.
Try closing down (regular bootup) all nonrelevant applications (also turn off your internet/wireless) and see if it works fine then.
Reply 29 of 35, by dj_anubis
the truth is that many time its stuck when FIREFOX is running in the background, the thing is i am not sure if its causing it, to chack it i will have to shut down firefox every time i play, and check after few times if it crahes or not
another question i have since 0.63 didnt suck even once, can i use the DLL files of 0.63 and copy only them to the 0.65 VERSION? maybe something in the newer DLL causing it could it be?
Reply 30 of 35, by wd
Rank DOSBox Author
DOSBox Author
Then maybe some firefox plugin or whatever likes to interfere.
Reply 31 of 35, by dj_anubis
and what about copy the 0.63 DLL to 0.65 version maybe it could work?
Reply 32 of 35, by wd
Rank DOSBox Author
DOSBox Author
I don't care about 0.63 or 0.65.
Reply 33 of 35, by frobme
DJ, the point is the authors can't support old versions because the code base has changed so much to increase performance/accuracy.
You've already demonstrated for yourself that DosBox is not the cause of the actual error. When you run in safemode, DosBox is executing all the same code, just using a different video output method. So it is not Dosbox code that is failing here, it's something in your video or sound drivers, or some other program that is running when you come up in non-safe mode (virus software, etc).
Saying that other games work fine proves very little. Those other games are using very different code to display their graphics, so it's just not a valid test.
You might try changing your output= line in dosbox.conf. Try overlay, or opengl. If it is graphics related you should at least see some kind of change to the behavior.
-Frob
Reply 34 of 35, by leileilol
try output=ddraw and machine=svga_s3
vgaonly and opengl brings pain.
Debian's fucked
Reply 35 of 35, by robertmo
first uninstall dosbox and install it to c:\dosbox cause you already fucked it up and changes you do to .conf doesn't work.
what is your Operating System?
what are your PC specifications?
