Ntvdm.exe
First post, by andee1
Hi 😀
More a minor problem yet annoying:
Everything works fine, but Ntvdm.exe causes 40% CPU - still no problem but the CPU-FAN runs like a thief - thats the problem - noise. 🙁
The idle CPU-Temp is 55°C and all silent. As soon as the games starts it goes to 62 - 63 and the FAN starts to scream. BIOS doesn't show any FAN settings. I don't wanna buy a new cooler system or CPU to fix this noise. Is there any trick, any setting in GLIDOS or windows to fix this issue? The temperure doesn't exceed 63 and I guess 59 would reduce the noise quite a lot.
XP@SP3
2GB@RAM
IP4@3,06GHZ
GF7950GT
GLIDOS 1.47
VDMSound 2.10
Reply 3 of 3, by andee1
Hm... so all I can do is set on the hardware. 😖 Ok. Anyway, thanks so much for GLIDOS that makes it possible for us to play especially Tomb Raider 1 with similar graphics of the following classic games on PC. 😁
XP@SP3
2GB@RAM
IP4@3,06GHZ
GF7950GT
GLIDOS 1.47
VDMSound 2.10
