First post, by lucky7456969
In the mid 80s, there was a software called "magic" something.
it allows you to change a monochrome display from text mode to graphics mode. Then you can play game on it. I can't recall exactly but with some melting/animation effect in the intro screen. I Believe it ran on dos 3.3
Hopefully any ideas?
Thanks
Jack
Reply 1 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
SIMCGA does the same thing, for the most part, and is more well-known.
Reply 2 of 8, by lucky7456969
Thanks a lot, thats the one. I am very grateful....
But I couldn't find it on the net, can you send me a copy?
Jack
Reply 3 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The screenshot is linked from another thread where a problem was reported with the app in recent releases of DOSBox. I don't have the software; but it displays a copyright, so its license probably does not allow copying. I think the reported problem may have been fixed in SVN, where a fix was made for SpaceWar with hercules video, but can't be sure. SIMCGA will do the same thing as Magic Key, if running CGA games on a monochrome display is something you really want to re-experience for nostalgia, or whatever reason.
Reply 4 of 8, by sliderider
Or you can find an old VGA grayscale monitor and play on that.
Reply 5 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The CGA on hercules simulators use dithering/banding to approximate shades, so the appearance is rather different than a VGA mono display. For example, here is a shot of Rampage (which does not have built-in support for hercules) in CGA mode using SIMCGA 4.0 and machine=hercules in DOSBox 0.74:
Reply 6 of 8, by eL_PuSHeR
lucky7456969 check your PMs.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 8, by lucky7456969
Thanks for your kindred help!
Have a nice day
Jack
Reply 8 of 8, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I can confirm that the SpaceWar hercules fix (r3617) has fixed the problem with Magic Key reported in the thread linked in one of my previous comments. Magic Key uses a different resolution than SIMCGA (640x200 vs. 640x300) and different dithering. If I had to choose, I think the Magic Key appearance is nicer when the aspect is corrected to 4:3, as there is less distortion than with SIMCGA.
