First post, by exofreeze
- Member
Has anyone gotten this game to run smoothly in dosbox? I have seen a few threads on here about using a 3dfx/glide type patch. Although I also saw notes stating that the menus are not visible under the glide patch.
here are my system specs & issue:
Motherboard: Gigabyte GA-P55-UD5
Processor type and speed: Core i7 860 @ 2.93ghz
Amount and type of RAM: 4gb DDR3
Video board: ATI Radeon HD 4870, 1gb RAM
Sound board: Onboard
Operating system: Windows 7 Pro 64
Game name (and version, if applicable): Dreams to Reality
Description of problem: The opening movie stutters horribly, the main menu blinks in and out while stuttering. Actual gameplay isn't as bad, but the resolution is stretched across the screen like some type of movie mode. I have very large black bars above and below the image creating a game image that appears long enough to cross two monitors. If I turn aspect=true on, then it fixes this problem, although the game begins to stutter even more.
Reproducibility of problem: always
Sound mode used: sb16 (220, 7, 1)
Video mode: I have tried all current SVGA modes (no_lfb, svga_s3, ) with a memsize of 64
Version of emulator: DosBox 0.74
Steps already attempted to solve the problem: tried all different VESA modes, tried maxing the cycles, and tried different versions of dosbox.
Here are some relevant sections from my conf file:
fullscreen=truefulldouble=falsefullresolution=originalwindowresolution=originaloutput=surfaceautolock=truesensitivity=100waitonerror=truepriority=higher,normalmapperfile=mapper-0.74.mapusescancodes=truelanguage=machine=svga_s3captures=capturememsize=64frameskip=0aspect=falsescaler=normal2xcore=autocputype=autocycles=maxcycleup=10cycledown=20
Thank you in advance for any assistance or advice.
