First post, by miami
i want to use dosbox with my program FC.exe and CG.exe (FC is invoice dos and cp compta dos)
DOSBOX is now running on my PC (Windows7_64bits)
i want to now if it is possible to have 2 Shortcuts:
1 to execute FC.exe D:\DOSBox-0.74\DOSBox.exe D:\MV\FC.EXE
1 and 1 to execute CG.exe D:\DOSBox-0.74\DOSBox.exe D:\MV\CG.EXE
also i want to exit DOSBOX when i close FC.exe or CP.exe
this two programs do not run together if that can help
also i have a probleme When I write a date or a number, I am obliged to do on/off NumLock for the number can be validated.
Can someone give me the command lines to put in options dosbox.option
thank you for your help
