not playable games
First post, by nuclear0508
i can't not play prehistorik 2. please tell me what i can do.
Reply 1 of 6, by eL_PuSHeR
I'm pretty sure Prehistorik 1 WORKS, at least, using VDMSound. Got to try Prehistorik 2 and post later... Gotta go to work now...
Reply 2 of 6, by eL_PuSHeR
Using DosBox it starts loading but after selecting play i got a scrollie screen, then an overhead map and then a black screen. It seems the game uses some undocumented/weird video routine somewhere.
Without using DosBox, it won't pass the overmap, neither. Black screen too.
Reply 3 of 6, by Nicht Sehr Gut
Originally posted by nuclear0508 i can't not play prehistorik 2.
Hrmm. My first thought is to emulate the Amiga original instead. *heh* Not what you want to hear I'm sure.
A dangerous choice of words for posters that have had a really long day. *heh*
Will try to find mine. Unfortunately mine is on a CD with an annoying "auto-DOS-menu" function that frequently doesn't work...so I'm not sure how representative it will be.
Reply 4 of 6, by eL_PuSHeR
For now, the best way of running this game is to run it under real DOS. If you don't have a SB or SB emulation, you'll still get some sound effects coming from the internal speaker. As Nich Sehr Gut suggested, get the Amiga version. It could be less painful to run.
Reply 5 of 6, by Nicht Sehr Gut
Originally posted by eL_PuSHeR As Nich Sehr Gut suggested, get the Amiga version. It could be less painful to run.
Actually, I was half-kidding on the Amiga version. I'm certain it runs fine in emulation, but I've yet to get to the point of testing the PC version.
Another issue is finding the Amiga version. It's not common apparently (still protected from public distribution). Can't even seem to find a demo. I can't even remember if I actually have it (something which is rapidly becoming a moot point as my Amiga floppies start to disintegrate...apparently leaving them in a storage shed for years is bad for them).
Reply 6 of 6, by Nicht Sehr Gut
With VDMSound in XP: Starts up, music and sounds work...right up to the point where you actually start...then...Oblivion.
In DosBox, it just drops dead.
In Win98SE, all audio was broken (either missing or horribly distorted), but the game played properly.
