First post, by EmuLover
Hello.
I was wondering if DOSBox can still be compile optimized for older PCs. We're talking PIII here. I have an older 733 Mhz OC'ed to 825 Mhz that I still use for various reasons.
Are there any pre-made DOSBox builds that may run well on this, assuming no 3D acceleration?
Reply 1 of 8, by Jorpho
Is there something in particular you want to do?
With such old hardware you could probably do plenty with a suitable DOS bootdisk, for instance.
Reply 2 of 8, by EmuLover
Run some apps while in Windows XP.
I take it the current source couldn't be optimized for Pentium 3s then?
Reply 3 of 8, by gulikoza
Most builds should be already optimized for p3...but no optimizing will make up for lack of power. But it should be fine for 286/386 era games.
http://www.si-gamer.net/gulikoza
Reply 4 of 8, by wd
Rank DOSBox Author
DOSBox Author
The compiler does it usually far better than you could optimize the sources.
And adding architecture-specific custom optimizations is not maintainable.
Reply 5 of 8, by EmuLover
Do you mean the actual program/method used to compile would make a difference (Visual C++ for instance)?
Perfectly understandable.
Forgoing the latest DOSBox app/game compatibilities, could someone recommend me a build that would run the best on a PC from this era?
-> PIII, 512MB RAM, Yamaha Sound, Matrox Graphics, Windows XP...
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
Various compilers have the possibility to target a specific architecture.
Reply 7 of 8, by TeaRex
Did you try installing simply the standard DOSBox 0.74? Was it too slow? And if so, was it much too slow or just a little too slow?
If it was much too slow even with core=dynamic and cycles=max config file options, there won't be much you can do about it. How about dual-booting your old PC into real DOS in that case?
tearex
Reply 8 of 8, by leileilol
If you have a competent soundcard with OPL2/3 you can use Hal's megabuild to use the OPL passthrough for a bit of a speed boost for those games that use adlib opl2 etc.
Use no scaler.
Also, 22050 every rate.
I still run DOSBox on machines 2 generations before the P3 for some CGA games that go too fast 😜
