First post, by VipertheSniper
I've read several of the posts regarding C&C RA running under Win2k/XP, and I've tried some of the stuff recommended there, but I wasn't able to get it running, mostly because I don't know how to use all the Option in Qfixapp, and well I don't have time now to try all the other things like ACP and whatever there is out there.
Well I guess some of you are tired of that question, but: "How do I get the Win95 installer of C&C RA to work?" (prefered solution with qfixapp as I already have that).
Ok and now to a topic I haven't found anything in this forum (maybe because it's a Dos-Game..?). How do I get "Z" to run under XP, just using compatibility modes doesn't work.
I hope you can help me out...
Don't bother to reply, even if you think someone already wrote the answer, the first day I can try it out will be next monday, so if you think someone missed an important point, post your thoughts...
pretty long first post. hope I can run this games under XP soon
Thanks in advance
Martin B.
