First post, by Silent Loon
I noticed a strange behaviour with one of my 486 boards (after I repaired the PC speaker - resoldered the cables). Its a UMC based 486 PCI board. The pc speaker beeps very often when I press a keyboard button to long or accidentically press two keys at the same time. I doesn't happen allways but frequently.
System uses AMD 486DX4-100 and 24MB Ram.
Phoenix Bios
Testing various bios settings didn't change anything. Happens in bios, in freedos & MS-Dos, so it doesn't seem to be driver or OS related.
Any suggestions what the reason for this could be?
Apart of the frequent "beeps" the system seems to work flawlessly.
Reply 1 of 5, by Silent Loon
Okay, I plugged in my old Siemens AT keyboard - no hysterical beeps anymore.
Seems to be some kind of incompatibility of the PS2 keyboard /adapter.
Nevertheless this was the first time that such a problem appeared.
Reply 2 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
There's nothing intelligent in the mini-DIN adapter so it's likely an incompatibility in the keyboard controller firmware or a bug in the Phoenix BIOS.
1+1=10
Reply 4 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Well it does work with all your other 486s? But yes it's possible that the others are more tolerant to nonstandard/'stretched' keyboard protocols.
1+1=10
Reply 5 of 5, by Silent Loon
I plugged in an old Cherry PS2 keyboard. No problems so far. So it seems to be an issue of the prodikeys (perhaps because you can use it as a midi input device as well?).
