Giant socket A/462 heatsink
Reply 20 of 26, by F2bnp
Hey does anybody know if you can use a stock socket 370 cooler on socket A without any problems?
Reply 21 of 26, by retro games 100
^ OK, cool (on). 😉
Re: skt 370 cooler on a skt A mobo - do you know what the dimensions are, for the underside of the cooler? I have used a heatsink similar to this one, and it works for both skt 370 and skt A. It's advertised as "for socket: Intel FC-PGA (Socket 370) & AMD (Socket A)." I think your chances of success with using a stock cooler are good, but I can't guarantee this because I don't have a stock skt 370 cooler to test at the moment, sorry!
Reply 22 of 26, by keropi
nice heatsink/fan collection rg100! (I could use one on my hot pIII-1.4 🤣)
socket370 / socketA heatsinks are interchangeable 😁
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 24 of 26, by F2bnp
Cool. I use a giant cooler for my Main PC's CPU, specifically the Scythe Mugen 2. It's gigantic and keeps my C2D 6550 quite cool, even in summer!
Reply 25 of 26, by retro games 100
I think the "slim line" cooljag socket 370/A heatsinks are very good. I like them because they also fit on Super socket 7 boards! 😀 I'm looking at the heatsink box it was packaged in, and it says:
ITEM: JAC301C
Application: AMD (Socket A)
INTEL FC-PGA (Socket 370)
Airflow: 23.3 CFM
Rated speed: 5200 RPM
The fan is very fast, and consequently a bit loud. However, it's very easy to remove it, and you can replace it with whatever fan you prefer. Perhaps you could do a saved search on ebay, for that item code of JAC301C?
Reply 26 of 26, by Tetrium
Just to answer your question, yes they will fit but P3's put out like half the heat that an Athlon (XP) does. Just be sure to use a cooler that's made for the Coppermine. The PPGA Celeron coolers weren't made to fit on the small naked die.
