Populous 2 Speed
First post, by navaji
The game runs way to fast and CNTRL F11 is not slowing it down....
Any advice?
Reply 1 of 7, by ripa
Change cycles to fixed and then use ctrl-f11.
Reply 2 of 7, by navaji
can you explain how to change cycles to fixed?
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
check the readme, check the dosbox configuration file
Reply 4 of 7, by navaji
Well... you where not much help, thanks 😈
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
If you found the answer there, I was of pretty much help. If not, just ask which part you didn't get.
Reply 6 of 7, by eL_PuSHeR
Hint. There is a chapter called '10. How to speed up/slow down DOSBox:' in the documentation.
Reply 7 of 7, by HunterZ
The new system of having ctrl+f11/f12 adjust CPU usage percentages when cycles=max is definitely going to be confusing to new users of DOSBox who are looking for ways to slow their game down. There's lots of information out there telling people to just hit ctrl+f11 a few times (see here for an example: The Newbie's Pictorial Guide To DOSBox ), and that obviously won't work. I doubt the DOSBox readme spells this all out in a way that makes it obvious to new users what exactly they need to do.
